| def | __init__ (self, name_of_subject="DummyUser", resultsPath="", output_headset_data_and_collisions=False, output_raw_sranipall_gaze_data=False, output_gaze_data_and_collisions=False, output_hand_controller_data_and_collisions=False, hand_controller_save_sampling_period=10, gaze_save_sampling_period=10, hand_controller_events_are_recorded=False, headset_save_sampling_period=10, operatorMode=False, activate_eyetracking=False, headset_manufacturer="Vive") |
| def | set_monocular (self, masked_eye=MaskedEye.LEFT_EYE, masked_eye_background_color=color.RGB255Color()) |
| def | translate_coordinate_system_along_global (self, translation=np.array([0.0, 0.0, 0.0])) |
| def | translate_coordinate_system_along_current (self, translation=np.array([0.0, 0.0, 0.0])) |
| def | rotate_coordinate_system_about_current_x (self, rotation_deg) |
| def | rotate_coordinate_system_about_current_y (self, rotation_deg) |
| def | rotate_coordinate_system_about_current_z (self, rotation_deg) |
| def | rotate_coordinate_system_about_global_x (self, rotation_deg) |
| def | rotate_coordinate_system_about_global_y (self, rotation_deg) |
| def | rotate_coordinate_system_about_global_z (self, rotation_deg) |
| def | get_axes (self) |
| def | get_rightward_axis (self) |
| def | get_upward_axis (self) |
| def | get_forward_axis (self) |
| def | get_position (self) |
| def | get_coordinate_system (self) |
| def | reset_coordinate_system (self) |
| def | SetIdScene (self, count) |
| def | add_scene (self, individual_scene=PTVR.Stimuli.Scenes.Scene()) |
| def | write_calculators (self, fp) |
| def | write_metadata (self, fp) |
| def | write_scenes (self, fp) |
| def | write (self) |
See PTVR Documentation:
https://ptvr_public.gitlabpages.inria.fr/PTVR_Researchers/recording_handcontroller_etc.html
Parameters
resultsPath: String
By default, the results file is saved in ...
...\PTVR_Researchers\PTVR_Operators\Results.
If you want to use another directory, create your own
(for instance : "C://great_folder//").
See Documentation:
https://ptvr_public.gitlabpages.inria.fr/PTVR_Researchers/results_of_an_experiment.html
and
https://ptvr_public.gitlabpages.inria.fr/PTVR_Researchers/change_location0f_results_file.html
output_headset_data_and_collisions: True or False
Record headset data in a distinct file.
Some essential headset data are output along with collision data (see
PTVR Documentation).
Sampling period is defined by headset_save_sampling_period.
headset_save_sampling_period :
It is used when output_headset_data_and_collisions is True.
Must not be smaller than 10 ms.
output_hand_controller_data_and_collisions: True or False
Record handcontroller data in a distinct file.
Some essential handcontroller data are output along with collision data
(see PTVR Documentation).
Sampling period is defined by hand_controller_save_sampling_period.
hand_controller_save_sampling_period:
It is used when output_hand_controller_data_and_collisions is True.
output_raw_sranipall_gaze_data: True or False
Record eye/gaze data in a distinct file.
All the data (including for ex. pupil size) provided by the Sranipal
software are output.
The sampling period is the one of the headset's eyetracker (for example,
for the HTC Vive Pro, it is ~8 ms as the eyetracking sampling rate is
120 Hz ).
In July 2025, PTVR still uses the Sranipal eyetracking application.
OpenXR will be used instead of Sranipal if possible.
output_gaze_data_and_collisions: True or False
Some essential eye data are output along with collision data. This is
the same principle as when output_headset_data_and_collisions or
output_hand_controller_data_and_collisions are set to True.
Sampling period is defined by gaze_save_sampling_period.
Note for output_raw_sranipall_gaze_data and output_gaze_data_and_collisions:
they can be both set to True.
gaze_save_sampling_period:
It is used when output_gaze_data_and_collisions is True.
This sampling period is approximately the refresh period of the headset's
screen (HTV Vive Pro eyetracker: ~11 ms as refresh rate is 90Hz)
hand_controller_events_are_recorded: True or False
It is used if 'output_hand_controller_data_and_collisions' is True.
In this case, the file used to record handcontroller data will
contain columns indicating which handcontroller events were recorded
during the experiment.
See Documentation: https://ptvr_public.gitlabpages.inria.fr/PTVR_Researchers/recording_handcontroller_etc.html
eyetracking: True or False
This parameter is used to save time when you do not
use eyetracking during an experiment.
If false, the eyetracking software (Sranipal) will not
be launched, thus allowing the script to start quickly.
If true, the script will start running after a longer delay and you
will be able to use eyetracking (Sranipal software).
headset_manufacturer : "Vive" (default) or "Oculus" or "ViveFocusVision"
"Vive" refers to the HTC Vive pro series headsets.
"Oculus" refers to Quest 1, 2 or 3 headsets (in keeping with OpenXR terminology).
"ViveFocusVision": for the HTC Vive 'Focus Vision'.
Returns
None.
Definition at line 63 of file Visual.py.
